So what does that sensor do on the hb? I would imagine it has something to do with the ignition.
So the crank sensor is only there for timing?
The exploder v8 does not use a dizzy hence 'distributerless ignition' the crank postition sensor tells the computer where the crankshaft is in relation to which piston is next in line for the 'dizzy' to signal to the coil pack to fire the appropriate cylinder. It is a pretty efficient setup, if only we could get the computer to work without the heated seats, airbags, climate control and all the other bs....
HeHeHe, I wonder why the computer won't work with without that stuff.
The crank trigger is only there for the stock explorer computer to figure timing.
If you run a distributer, that ring is an extra part that does nothing.
But leave it there because someday there will be a neat distributerless conversion coming that will use that ring.
