I have installed the mountaineer [ 1999] belt system on my truck and was wondering if the steering pump and pressure hose connection is the same as the explorer unit? I took my hose to my local hyd hose shop and they added the adapter for my old gearbox and lengthened the hose. my problem is the pressure fitting going to the pump is loose and was wondering if I was lacking an Oring on the end of the fitting. There was a seal on the end of the fitting that was on the shoulder of the fitting but is there also an O ring or Teflon seal that goes on the threads? any help would be appreciated.
bill
bill
