Bronchole
The length of the arms is not the only thing that affects the caster. The lowering of the pivot end of the arm affects it too. If you extend the arm you will likely end up lowering the the pivot point that the arm pivots on. (distance from the ground). Since the arm are slopeing down from the pivot to the axle, lengthening them will also reduce the angle of the arms to the ground. Reducing the angle of the arm to the ground will increase the positive caster angle which will usually help make your Bronco steer better. From what I understand you shouldn't expect more than a degre or 2 from this unless you go crazy intentionally dropping it ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Dan
Dan
