Anyone know of an external inline HP fuel pump for EFI that has a higher output than the standard E2000, late 80's Full size truck/van pump? I was doing some homework and reading in the Ford Motorsports catalog, and saw the E2000 pump generally can support 250hp at flywheel. I suspect my set up is going to yield a bit more...but not a fire breathing monster than needs a 255lph pump. From what I read, the E2000 pump appears to be somewhere in the 88 to 100lph range. I'm thinking I've seen or heard of 155lph, or somewhere in that range, inline pumps. What are you running? Does what I'm looking for exist, or is it stock or high output 255lph only? TIA
