The OEM ground cable had a mid-span lug at the frame bolt that I couldn't duplicate. I had no option but to make the ground cable two separate cables and stack the lugs on a longer bolt.
A former co-worker of mine was once put on the solder vs. crimp debate by Boeing and told to resolve it. 18 months later he did. They're equal. BUT with some important caveats. The crimp must take the cold-welding to the point where a cut thru the crimp, once smoothed & polished, does not show the boundaries of the individual strands, but not so far that it extrudes the crimp zone and makes it longer. A soldered joint relies on cleanliness and the experience of the person doing the work. In the end it was felt that it was easier to design and mfg crimp dies with the correct dims than it was to try to train up a huge crew of solderers.
I use a Greenlee hex die cavity crimper for all of my cable crimps. This is all color-coded for NEC type electrical work. In that work you have to use the brown banded lugs on a particular size of cable, and crimp it with the dies marked with the brown dots. These dies leave behind a mark in the crimp that indicates to an Inspector which size die the crimp was made with.
As I don't always use an NEC cable lug on the intended cable I'm pretty sure that I'm not always getting a perfect crimp, but I am being very careful about which die I use on each cable.
I have the regulator pigtail and the cheap regulator should be here today.
