Extreme cooling fix?
jckkys
After 40 yrs. and three EBs I still have no answer for a hot running engine when the Az. summer brings 110 degrees or more.The engine temp starts to climb over the thermostat setting when the air gets over 100.With an aluminum radiator and all normal over heating causes (lean mixture,over advanced timing , etc.) fixed, I'm looking at more extreme,or expensive measures.One is ceramic thermal coating of the combustion chambers and exhaust ports by Swain Tech Coatings.This would run about $500.Has anyone tried this? If so, to what effect?The other fix is louvers on the wheel wells and or the hood. Does this work?Yes I have a good fan shroud and have tried several fan types. None have helped.The engine is a 351w but the 289 and 302s were no less inclined to run hot.The summers here are HOT! Many vehicles of all types have the same problem when driven in hot whether,so my Bronc is not malfunctioning it's just trying to deal with an extreme condition that pushes things to the edge. I'm looking to get a cushion that will allow traffic jams and climbing grades to be less of a worry.
broncnaz
Have never really had any issues with running hot here in AZ and mine was a daily driver for awhile when I lived in tucson. The only time I had a little issues was with a 4 row radiator and it was more due to the tanks always leaked on it. Went back to a stock type and it rus where its supposed to all summer long. What are you calling running hot? What T stat temp are you running? Fan? Shroud ect?
As for coatings dont know if they will help or not I imagine they will help though. I would look at thermal coating the exhuast inside and out wether you have headers or stock manifolds that will help keep quite a bit of heat out of the engine bay. There are a lot of other little tricks that have helped people as well. I'll see if I can find some links. Might just do a search on the subject as there are a lot of posts on this topic.
70_Steve
Old Guy
I have been running a 351 for 8-9 years with no problems cooling in the AZ summers. I had the radiator recored with a 4-tube core about 13-14 years ago when I still had the 302. I run a fan shroud, stock 7-blade fan, and stockish temp thermostat (180° w/carb, 195° w/EFI). Not sure if the pulley sizes are stock, but the crank pulley is 6 1/2"dia and the pump pulley is 5 3/4" dia. I do run the cross-over at the rear of the intake, and have that connected to the return hose for the heater. I did run the stock water pump, but when I had the engine rebuilt a year ago, I bought a Flowcooler waterpump, since WH had them on sale.
I was wheeling last year at 115° and the hottest the gauge got was 200°.
Does yours get hot at idle or at speed?
J
jckkys
Again,it's a stock fan and shroud. The cross over hose is redundant because the Performer EGR intake has a coolant cross over passage built into the back end.The engine coolant often hits 220 regardless of the thermostat ,170,185,or194.I call 220 hot.The problem is aggravated by high speeds,like over 60,long grades,or slow stop and go traffic.I intend to try a water pump with an inclosed impeller like the Flowcooler when the stock one starts leaking.I'll try Purple Ice when it gets hot.It's only gotten to 100 so far.I'm getting ready to do a frame off so mods that are easy when everything is apart need to be done as part of the process.If wheel well louvers work. Now is a good time to do it.I don't like headers for EBs.The 351 PI now has GT40 heads and comes with the same cam as the Lightning so there is plenty of power. Plus headers really heat up the engine compartment and don't help low end torque.The louvers are a way to let hot air out so more air can flow through the radiator.It's not a new idea but how effective are they on an EB?The ceramic thermal barrier on the combustion chamber and exhaust ports is intended to keep some of the heat in the exhaust instead of going into the coolant.So far I can only find this treatment being used on the internal engine components of race cars,where a few extra HP can justify the cost.
70_Steve
Old Guy
I know I guy that has a gorgeous 55 Chebby resto-mod. Has all the goodies and he really tried to do everything right the first time, like installing a brand new BeCool radiator. Right from the start he had cooling problems, mostly at speed. He tried every trick in the book to get it to cool and wound up overheating and ruining his new 383.
He was determined to find the cause of the overheating so since he had replaced every part of the cooling system during troubleshooting except the radiator, he took that new BeCool radiator to a shop to see if there were any problems with it. He told me the guy looked at it for less than a minute and said "There's your problem!" Apparently during manufacture, the radiator was over-pressured, and the tubes expanded. This cut down on the air flow through the radiator causing the overheating.
Another radiator (not a BeCool) fixed the problem.
blubuckaroo
Grease Monkey
Ridgefield WA
jckkys,
Is this a problem on this particular Bronco or on all three you've owned? Have you checked for restricted exhaust or a kinked radiator hose? How many passes and what size tubes does your radiator have?
I live in an area where we have high summertime temperatures too. Our local radiator shops are the experts on cooling so that's where I went. I was told that a good staggered core three pass brass radiator is the best bet. They told me to use only one gallon of antifreeze instead of the 50% I had been using. Install an RV rated flex fan, 192 degree thermostat, and close up the area in front of the top of the radiator to keep hot air from recirculating through the radiator. I can idle in 110 degree traffic with the A/C on and the gauge is around 200 degrees.
70_Steve
Old Guy
Oh yeah, I forgot about that. I didn't have cooling problems before, but I did notice a difference after installing the RAD (Radiator Air Deflector) from American Broncos. It blocks the space between the radiator core support and grill. Easy enough to try with some cardboard and ductape.
http://www.americanbronco.com/products/fenderskirts-cooling.html
As for the $500 in coatings, no that isn't a magic bullet. I (we?) played with various ceramic coatings for the past 15 years. Everything from piston tops to exhaust tips. Benifits are very minimal, and not $500 worth of benifit when you can do it at home just as well for under $100. Even then it isn't nearly the barrier they claim, but more of a dispersiant. That is it evens out the hot and cool spots. Quick tests (advertising tests) will show it is cooler, where it shows cooler because the heat is conducting into the coolness and not really reflected back.
There are times when having a job at an automotive proving ground comes in handy. As well as co-workers who are interested in it as well. and some nice test equipment to work with as well.
broncnaz
Well I've run my broncos in AZ for well over 30 years both in stock and modified form with no issues. 220 is not that hot if your pulling a hill, stop and go ect. but I know what you mean you'd like to get it down a little. but ambient air temp dictates how much heat can be transfered.
Yes louvers can help as can taking out the inner fenderwells.
If you dont like headers well thats fine. they do improve power and if coated will reduce underhood temps. but stock manifolds can be coated as well.
I would second the comments about older radiators. They do tend to build scale inside and become less effiecent. I've never tried them but the thriple pass radiators that some of the venders sell may be a option for you as well in that case I think a flowcooler type pump is in order to help move the water through the system.
Still all said and done a stock cooling system should work just fine in the AZ heat as there are many of us running around without issues and without louvered hoods or any other mods.
J
jckkys
I truly appreciate all the input.My goal is to build a better Bronco that can tour the country comfortably,economically,and dependably while keeping the look and feel that Broncos had in the 60s and 70s.So I use Ford parts when I can. When I can't, I try make them look original.The exterior,interior,and engine compartment look like it did in 77.The exception is wheel well flairs that many if not most Broncos had in the day. I think the rear wheel wells were a mistake that the factory should have corrected.
broncnaz
Heck a lot of people think the flairs were factory they ask why did you cover the wheels when you are uncut. My bronco has been from coast to coast and north to south not very many states it hasnt been in but there are a few. I'll drive it anywhere.
here's another option you may want to look into not real noticeable like louvers would be. http://www.wildhorses4x4.com/product/Ventilators_Inner_Fender_Vents/early_bronco_vents_ducts
but still like I said many of us havent done any of these mods and still run in a decent range when its hot. usually you dont have to worry about overheating until your over 240 and puking water.
bad 68
Northest Washington
In order for the EB cooling systems to work correctly you need a catch tank. They will have cooling problems until all of the air is burped out of the engine. You can't do this without a over flow bottle.
I know this after about 15 years of summer heating problems. It all went away in a day.
