crawln68
- Oct 8, 2004
- 3,045
69patriot76 said:Yes, this will work with a 5.0 conversion.
Awesome. I think I'll have to give him a call and order one up. Thanks for all of the information! Good job!
Electrolysis will occur in aluminum radiators if they are not grounded. All it takes is running a ground wire from the radiator to the body to prevent it.69patriot76 said:Oh, another thing he mentioned in regard to the aluminum radiators that some of us are running. He said that with some rigs that run a lot of onboard electronics or fuel injection with a lot of wiring that there is a very high likelihood of developing a low voltage charge in the entire engine/cooling system that will cause electrolysis to charge the coolant and rapidly break down the aluminum cores. I'm interested to hear if this has happened with anyone.
BRONKEN said:Any updates? I'm ready to order one and wanted some feedback first.
Brewbro21 said:Did he say if he would move petcock or wouls we have to? Also will he adapt it for the manual tranny or do we have to do that also?
Yes any updates would be awesome.
chuck said:Since you included my name maybe you should do a little more comparing. Like how thick is the metal of your radiator tanks,tubes and fins? You have the radiator, put it on a scale, how much does it weight? Mine weighs 28 lbs. is 3 core and fits in the stock brackets. I just weighed one that is dry inside. I don't think 4 tubes in the space of 3 is better, what that realy means is that the tubes are smaller so will plug up easier and restrict flow. (restricting the flow may not be bad) I do charge a core but most people do not return them so most of the radiators are all new parts. In the 8 years I have been selling this hi density radiator I have only had 1 person complain about a leak and only 3 that complained that they were still over heating after installing my radiator but I have sold a few hundred to people with heating problems.
I have no problem with you coming here saying you found a great radiator for a very good price. I am not saying that the radiator you found is not good The price and shipping I can not compete with but please compair apples with apples.
The reason for the core charge is to hold down the cost. The new tanks and straps cost me $50. It would be easier to just charge the extra $50 but that would end up costing the customer $50 and he would have a radiator laying around. It seems that most keep their old radiator around anyway. The guy that builds radiators for me will not use cores that are not in great shape so I end up eating one once in a while. According to my radiator guy there is only one company making good tanks. Several others make them and for less but they are thin so tend to crack. But the stock tanks are still holding up except for getting beat up, people cutting holes and salt damage.BRONKEN said:Chuck, with most of your radiators being all new parts, why have a core charge. That might be a decideing factor for some of us. With so many other new radiators out there (someone is producing new tanks) is there still a demand for stock tanks? Also is your radiator specifically made to your specs?
Thanks, Ken
SaddleUp said:Electrolysis will occur in aluminum radiators if they are not grounded. All it takes is running a ground wire from the radiator to the body to prevent it.
Hmm.. Just did a bit of research on this. It isn't limited to aluminum radiators. Apparently it can occur in any radiator and even in the engine block if the grounds are bad.
69patriot76 said:I'm glad you don't have a problem with me coming here and saying I found a radiator at a good price. Thanks for that. I haven't even run it yet, and have never said it was great. As for comparisons, next time I won't include anything of yours since it isn't an apple. I am not a radiator expert, I only compared price and obvious physical features. I don't know how much it weighs and don't care. It's a NEW radiator and it's mounted. I'm sure it will be better than what I had. Since I'm not running Baja, I'm not too worried about it being perfect. I just wanted a new radiator, saw that this one was cheap and had some features I wanted and wanted to share the info with others in this non-vendor managed public forum.
By the way, that question about you charging core costs BUT shipping new radiators is a good one....
69patriot76 said:I guess you'd have to braze a wire directly to the tank to ground it, right? That makes sense. Yet, I do know that aluminum is prone to greater damage than copper. Whether in a radiator or elsewhere.
My question is... if this can happen in any radiator, why haven't the manufacturers been installing grounding wires on all of them? With the billions of vehicles out there, you'd think that the builders would do that. Can't be that expensive. So, I'm thinking there is a reason that they don't do it and why radiators are typically insulated from contact with any other part of the vehicle.
I'm thinking that with so many different types of radiators available for our rigs that someone with a lot of money and time should buy one of each and do a true "consumer report" and run a scientific test. I only know it won't be me.
