SaddleUp
No, I just ran the wire from the top of the radiator to the body. Actually my reason for doing this was to dissipate any static charge created by the electric fan. Here is a better explanation of the problem with electrolysis and how to correct it.69patriot76 said:I guess you'd have to braze a wire directly to the tank to ground it, right? That makes sense. Yet, I do know that aluminum is prone to greater damage than copper. Whether in a radiator or elsewhere.
My question is... if this can happen in any radiator, why haven't the manufacturers been installing grounding wires on all of them? With the billions of vehicles out there, you'd think that the builders would do that. Can't be that expensive. So, I'm thinking there is a reason that they don't do it and why radiators are typically insulated from contact with any other part of the vehicle.
I'm thinking that with so many different types of radiators available for our rigs that someone with a lot of money and time should buy one of each and do a true "consumer report" and run a scientific test. I only know it won't be me.
http://www.rondavisradiators.com/tech.htm
