F350 1996 auto trans/351W conversion
1957
Rome, NY
I may be able to get 1996 F350 w/351W & auto transmission. Would any one of you folks know what type of trans is in there? This vehicle 100 miles away and I won't be able to get the tag information. Would it be an AOD? I have a 69EB that I am working on that I would like to change to an automatic. The engine I am not concern with the engine about because I have a 289 to go in. But the trans I am really interested in. I will check with a local Ford dealer and see what they say-but 1st I rather ask you experts first. Any info is most appreciated. Thank you.
Tony
El Kabong
Driving stuff Henry built
I'm no expert, but here's my 2 cents anyway. A 96 Bronco would have an E4OD. From 90 up the 351s got it. I would think the F250 would too. It's a bigger, heavier, stronger, longer trans than an AOD. Sort of an electronic C-6 with OD. It's computer controlled, so you'd need to provide for that, & the size might make it tough to install in an EB.
The AOD is smaller, & doesn't require the computer control. The AOD came behind 302s for awhile, but by 96 I think even the 302s used the E4OD.
Thinking about it, FSB's Tranny Info thread would have more details. I hope you don't mind the crossover between forums. If they could check the door sticker for you, it looks like the AOD would have a door sticker trans code "T", while the E4OD would show "E".
...Model: E4OD
Type: Electronic Four speed Over Drive
Years:
'90-'96 Bronco,
'89-'98 F-Series
Engines: {300, 302, 351w}, {460}, {7.3L IDI}, {7.3L PSD}, {5.4L}
Display: PRN(D)21 w/ overdrive lockout switch
Pan: 20 bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E
...Model: AOD
Type: Four speed non electronic
Years:
'85-'93 F-150
'85-'89 Bronco
Engines: 302
Display: PRN(D)D1
Pan ?
Fluid: Mercon
Ratios:
1st 2.40:1
2nd 1.47:1
3rd 1.00:1
4th 0.67:1
Trans code: T...
Tony
Since you are asking the same question in different posts...
Either an E4OD or a C6. You will need to look for an O/D off button. If it is there, E4OD, if not (and a vacuum line to the trans) then it is a C6.
It is not the transmission you are looking for.
yes, it could be a C6, '96 was the last year for that transmission. I was surprised when I found that out as well.
1957
Rome, NY
Well I found out is a C6 not with overdrive. Not sure if I should put the 351W in with it. I have a 289 I rather use. Most likely I have to buy the engine with the 351W. I will keep searching the treads for folks that swap a 6 cyclinder for the 351W. Some indications are that their may clearence height and exhaust clearence problems. Thanks for all who commented. You and this site have been a great help. This is a great FORUM
Tony
