Factory Hand Throttle
74bronc
Trying to find out the history behind a knob that is installed near the fuel gauge selector switch on the dash that is labeled "Throttle". My first thought was a hand throttle but I am not sure if they were offered from the factory or as a dealer add-on. Does anyone know for sure? Has anyone seen anything like this before? The bronco is a 1975 model.
J-DUB
Edmonds
My '69 had one. I used it to warm up the beast. I would get it started the apply a little pedal to get the proper RPMs and then pull the hand throttle out and it would sit at that RPM. Worked great when it was a$$ cold out.
GusI
Issaquah, WA
My 72 Sport also has one and I believe it was factory installed. I always remember it being there and the truck has always been in the family.
74bronc
74bronc
Thanks fellas. That's what I thought. make sense.
iwlbcnu
My 76 has it.
Factory cruise control before the lawyers jumped in ;D
MKD
Edgewood, NM
My '68 has it and it was factory. I've used it many times on trips for short periods to allow me to move the old leg around. It just keeps the accelerator pedal where you left it but I've found it only does this for so long, like a few minutes, before slowly letting the pedal up. I don't think it was meant to be used while driving. Just for PTO or warm-up purposes.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
My '69 has it. I've tried using it as a crude form of cruise control, but as MKD also posted, it won't sustain highway speeds. So like many others, the primary use I get out of it is for warming up in the morning.
