76 bronco J
- Oct 20, 2005
- 1,480
>>>>>> I noticed a thread lately from bluebuckaroo on his 1250 intake gasket leaking so I thought I add a bunch of links here from some sites I've seen talking about the soft non-steel core printo seal type gaskets.....I've had my own share of issues with the printo seals shifting around the intake ports ,but no coolant leaks luckly.. I use a very very small amount of the "right stuff" sealant these days around the coolant ports......I've glued them to the head with edelbrocks gasacinch & permatex high tack a they still eventually shifted or split(more than once),see below .....I also use the "right stuff" in place of the end seals & use permatex high tac on the bolt threads for oil seepage,since it doesn't harden which is good for repeated retorques........ we have been told time & time again that we must use the soft printo seal style gaskets with aluminum intakes ,but the stock 5.0 has had a aluminum intake with stiff steel core gaskets from day one..... now days it seems ford racing & fel-pro consider the regular 1250 & 1262 printo seal gaskets for race use where you don't leave the intake on for long term street use...... the new part#s are 1250 S-3 & 1262 S-3 ,they are a steel core intake gaskets for long term street use......there is another steel core made by fel-pro only available through ford racing for there Y & X aluminum heads part #M-9439-A50, this gasket showed up back in 2005ish before the other 2 new gaskets from fel-pro & this one is marked 1262-S on the gasket itself .... I'm running the old Y heads with a performer 289 & the M-9439-A50 gasket & it's less than ideal cause the peformer needs a little more material at the top of the runners cause' of the tall ports on the Y heads...... from searching seems lots like the victor reinz intake gaskets....... main thing for intake gasket searching is port size, early or late coolant ports,ERG pre cutout or not,EGR block plate supplied or not & now it seems you need a steel core gasket for long term street use...... anyway here's some reading below >>>>>
http://www.capitalareacobraclub.com/index.php?topic=5095.0 fel pro press release FEb.23,2006>> http://federalmogul.mediaroom.com/index.php?s=43&item=89&item=89....... http://forums.corral.net/forums/showthread.php?t=980854 ...... http://www.ffcobra.com/forums/showthread.php?t=178867 ........ http://www.mercurycougar.net/forums/showthread.php?t=37879 ....... http://forums.stangnet.com/527295-intake-gasket-question.html ...... http://www.fordmuscle.com/forums/all-ford-techboard/458218-408w-questions.html ....... http://www.clubcobra.com/forums/showthread.php?t=80530&highlight=intake+gasket&page=4 ....... http://www.network54.com/Forum/7418...ay,+Victor+rather+than+Fel-Pro.+.+.++Question ...... http://forums.corral.net/forums/showthread.php?t=1074956 ....... http://www.allfordmustangs.com/forums/5-0l-tech/155801-intake-head-issue-1988-mustang.html ...... http://forums.popularhotrodding.com/70/6591003/got-your-tech-right-here/302-ford/index.html ...... http://www.store.partsdinosaur.com/page80.html
