Fender Flares???
Cooper2771
Hi all, looking for some suggestions on fender flares for 1974 Bronco II that do not rquire a ton of cutting.
I ordered the Gorilla Warflares from Wild Horses but they are going back because of the amount of cutting.
Anyone have any suggestions???
Grey owl
????? 1974 Bronco II ??????
.94 OR
Willamette Valley, OR
Does Bushwacker still make flares for these?
That is what I put on mine, 30+ years ago. I never did cut the front metal fender since my lift and 31's fit fine without doing so, the flares to me make a more uniformed look front to rear and give a little more lateral mud protection. The painted fender pretty much hides under the Bushwacker and the rears matched the cut out from the original fiberglass style flare.
ngsd
They all require cutting so I am not sure why more would create a problem. Once they are cut then cut away! The gorilla warflares to me are the best ones made currently.
Shimmy
1977 Bronco
Maple Valley
i'm happy with the Tom's flares. as mentioned they all require cutting but i feel like mine aren't that aggressive, which i like
So Cooper, what’s your goal? Do you just want flares to stick out to cover wide tires? Are you trying to get the look of the open fenders? Or do you have tires that are too wide just for the rear and need to open that up a bit?
