Few last minute questions
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
Well, here goes. Any help would be nice
#1 - What is the difference in ignition boxes ( ford boxes ) and how do you tell them apart ?
#2 - Can I find a gas tank sending unit SEAL local ?
#3 - Previous owner boogered up the wiring to alternator. He had two batteries and a finned aluminum box wired to this bronco. So, some of the alternator wires are chopped and taped back together and one has no end at all. If I go to the junk yard and chop a foot of harness off of something can I just solder the wires back together and not have a problem ( I think I read somewhere that the wires are special wire ? ) I totally stink at wiring :(
Thats it for now ;D I'm probably going to think of something else later.:)
72Sport
#1 - What is the difference in ignition boxes ( ford boxes ) and how do you tell them apart ? I have seen the conversion in the links. You might try this for some info:
http://meb.bronco.com/techinfo/mods/duraspark/duraspark.html.
Duraspark 1? wiring diagram: http:classicbroncos.com/forums/showthread.php?s=&threadid=43188
#2 - Can I find a gas tank sending unit SEAL local ? Ford Dealer.
#3 - Previous owner boogered up the wiring to alternator. He had two batteries and a finned aluminum box wired to this bronco. So, some of the alternator wires are chopped and taped back together and one has no end at all. If I go to the junk yard and chop a foot of harness off of something can I just solder the wires back together and not have a problem ( I think I read somewhere that the wires are special wire ? ) I totally stink at wiring :( I haven't had any luck. Vans and pickups seem to have the male and female plugs reversed to my 72 Bronco
The Duraspark II boxes are told apart mainly by the color of the wire strain relief (grommet) where the wires enter the box. Blue is the most common for swaps and one of the easiest to wire.
You should be able to get a gasket I would think. Not sure what all they fit, but I imagine they fit a BOATLOAD of vehicles. Have you tried the dealer?
Keeping the finned box (battery isolator) is probably the easiest way to re-wire it and that way you still have a simple dual-battery system.
Does the finned aluminum thingy have at least 3 threaded posts on it? If so then it's undoubtedly an isolator. The main charge wire out of the alternator (Black w/yellow stripe) can go straight to the "IN" post (probably the center one, but check first.) and the one coming out of the firewall can go to the "BAT 1" post. The "BAT 2" post can be left alone for now or you can run a wire at least the same size as the other one to the positive side of the secondary battery or wherever it's connected to a system.
All you'll need then are crimp-on ring terminals to attach things together. And you should use at least 8 ga. wire for safety. Bigger if you're running a high-amp (more than 70) alternator.
Can you post a pic so we can see just what you're working with? Can't hurt anyway.
The only thing I know of that would make the charge wire special (at least in the engine compartment) is the fusible link in the wire at the starter solenoid, and maybe another one in the loom probably closer to the alternator. But you don't HAVE to use that type of setup if yours is all whacked up. If you don't have a fusible link you can use a maxi-fuse to protect the circuit.
Is this on the '69 or the '73? At various times Ford used Black w/yellow, Black w/red or just black for the charge wire, but it's easy to find since it's the largest wire in the loom usually except for the battery cables. If you have multiple colors, usually the Black w/yellow is OUT of the alternator and into the firewall, and Black w/red is back out of the firewall and to the starter solenoid/relay. It may be just Black, but probably has a stripe.
Hope that helped some. Let me know if any of that needs clarifying.
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
DirtDonk, thanks for the reply. I am using a 75 wiring harness in the bronco I'm building so it has a ignition box but I'm not sure if it is good. I went to NAPA and asked for a new one and they asked what box I had. SO, I would imagine I would have to tell him green because that is the color of the plastic gromet coming out of the box ( does that sound right ? ) . As for the isolator , it is long gone. I am trying to repair the harness back to normal.
edjolly
Denver Colorado
Green is the right box for a '75.
As for the wiring, there's nothing special about those wires, except the fusable link. You can buy fusable link wire at NAPA, and it solders in as well.
Ed
OK, cool. In that case, butt-splice the wire coming from the alternator's "BAT" terminal to the other Black w/yellow wire that goes into the passenger compartment. Does the '75 harness have that wire going into a 3-prong plug somewhere in the engine compartment before the firewall? You could crimp it close to there. You can add your own wire to it if you need to add some length. Any similar wire would be adequate as long as it's at least the same size as the Black w/yellow wire. I'm looking at one right now and I figure it's either a really thick 10ga wire or a moderately insulated 8ga. I'd err to the side of 8ga. as it's pretty heavy duty and sees some decent current over that LONG run of wire.
Is this a '75 Bronco harness? I'm assuming yes but I don't know what color grommet Bronco modules came with and whether they were different between CA and FED like some were. But you can ask for a box for whatever the donor vehicle was and see if they pull a green grommet box. If not just ask them to pull several different part numbers off the shelf and loof for a green one. If this doesn't work, just get the blue one and we'll make sure you hook it up right. But because those unique to Ford plugs are matched to each color in most cases, it'd be easier to start with a Green box I imagine. Plug-n-play that way hopefully.
What color are the wires coming from the box and how many plugs does it have? Should have 2 plugs, but some had 3 and maybe even 4. You'd want one with 2 plugs normally.
Having fun yet?
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
This is a picture of alternator wiring . Note the small wire in bottom of picture coming out of that black thing ?:?
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
And this is the old box. Note - see he has one wire cut for some reason and pulled out of the plug but why ?:?
Hmmm, veeerrry interesting. The Orange wire is the "F" or Field wire and that looks OK. The larger wire coming out of the molded relief looks like the right size for the BAT wire, but I don't see all the colors too well.
Normally on a stock '75 Bronco there would've been the Black w/yellow (largest) wire, the orange wire, a White w/black "S" stator wire that goes to the electric carb choke, and the small Black w/red ground wire that is internally connected to the little steel mounting loop molded into the rubber. Is that what you have? If not sure what each one does by color or size, just check each one's continuity to verify where it comes out. If the cut one is the stator wire, no big deal unless you want to run an electric choke. If it's the ground wire then you should run a separate wire from the "G" terminal on the alternators case to one of the bolts that holds the voltage regulator on the body.
The orange one goes from the F terminal on the alt. to the F terminal on the regulator.
If it turns out that yours is messed up beyond repair or you're just not happy with something and don't want to make your own, let me know. I've got a spare one you can have. But you can make your own if you have to. There is nothing special about the stock one other than it's set up to sort of bolt on in one piece and has a well protected ground. I had to make my own when I went to the bigger alternators.
On the module, it looks like that red wire could be the main power in to the box, and could have been spliced because the original plug was messed up, or the box didn't match the plugs that were on the donor vehicle (there are several different configureations) or the P.O. was just being, well, a P.O. and as we now know, P.O's don't know diddly about wiring.
But there is something strange if those colors are right. I know edjolly confirmed Green as the right color for a '75 so maybe you can match these colors for us. I have two diagrams and they show different orientations for the '75 in each.
The Chilton's shows:
A two-prong plug with a Blue and Red w/blue wires.
The four-prong plug has a Green w/yellow, Orange w/yellow, Black w/green and a Purple w/blue wire.
The Haynes book shows:
A 3-prong plug with a Blue, Red w/blue and a Brown wires.
A 4-prong plug with Purple w/blue, Black w/green, Orange w/yellow and Green w/yellow wires.
Does one of those make more sense than the other? Hope so.
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
I will check the plugs and colors tomorrow and let you know right here on this thread.
As for the alternator wiring - I'll untape it tomorow and see what I can find. thanks
Cool. Glad it helped. Was it already in the truck when you bought it and is it hooked up? Isolators are a pretty decent way of running duals in a Bronco. It's not considered the most efficient these days with all of the other choices around because you do lose a fraction of the voltage going through the isolator, but it's still a clean way to do it while keeping the ammeter in the loop and not having to hack up your wiring to do it.
Glad that helped. Is yours up and running?
Now, if any of you have nuclear meltdowns after this, my name is actually, er, Fred. Yeah, yeah, that's it. Fred.
Paul, er, uh, oh the heck with it.
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
DirtDonk, I checked the colors of the wires for the ignition box for you. I have two plugs
A three prong plug with - brown, blue, and red w/black stripe
AND
A four prong plug with - Green w/yellow stripe, black w/yellow stripe, orange w/yellow stripe, and purple w/blue stripe
Now, as for the alternator. It looks as if the only wire cut is the large black that goes to " bat " and only the end is missing. I hooked the orange wire to " fld " and I have the " sta " empty. the small black and red wire seems to be in tact but the light colored wire is cut. That is the wire with about half inch sticking out of that black thing in my picture.
Now, the small black with red stripe wire you say is built into that black thing. Does that need to be on the " grd " terminal or is the other bare terminal okay to use ? See picture.
Good pic, that helps.
Yes, the small black w/red stripe wire (ground) can go to any of the case studs really. The one marked GRD is usually not in the right place, so the other one can work fine and is in fact where all the Ford hookups that I've seen (including Bronco) go.
The Field is good to go.
The BAT wire is your main man so make sure you splice a good piece on to it. Is it currently (electrical pun, arr, arr) long enough to reach the isolator if you just crimp a ring terminal on to it? I can't tell in the pic. If not, you have two choices. Either extend it enough to reach the isolator, or just don't use it and make a new wire to go from the BAT terminal to the isolator. Up to you, depending on what you need.
The STA wire is kind of a mystery as far as the color. At the plug w/boot in the picture, it's a dark color. I know they get hot and lose there colors over the years so maybe it's just how it looks, but is the upper wire with the black boot the "light" wire that is cut? If so you can either leave it hanging, or better yet just attach it to the appropriate terminal and seal the other end. Or use it for your electric choke if you need it. Again, up to you.
Looks like Mr Haynes gets the nod on the wiring diagrams. I think I'll mark that in my other books for reference.
You've got a little bit of a strange one so make sure you tap into the correct circuits for each. They don't match the standard Blue Grommet box so you will have to make sure you get a matching Green box if you carry a spare, which is a good idea anyway.
Are you using the ignition switch and under-dash harness from the '76 also? If so this will be easier.
The Red w/blue (or black) wire goes to the ignition switch's "START" only circuit. It may very well be soldered to the same connector as the Red w/blue wire to the starter solenoid. Same circuit, separate wire.
The Brown wire is spliced into the Brown circuit from the starter solenoid's "I" post. This tells the module to retard timing a few degrees making it easier to start I believe.
The Blue wire is full 12 volts from the switch and shares the plug with the resistor wire to the ignition coil as well as several other circuits spliced into the line.
IN the 4-prong plug, the Green w/ yellow wire is your signal wire to the "-" side of the coil to tell it when to spark and should already be hooked into the Horseshoe connector for the coil unless it's been cut.
The other three all go to the distributor's matching plug and should be good to go. The Black w/green wire is specifically grounded to the distributor body just inside the grommet and the other two are the signal wires from the magnetic pickup.
Generally, Ford mounted all their ignition modules to the rear portion of the driver's side fenderwell. That's one of the coolest areas of the engine compartment. I mounted mine to the front of the same fenderwell due to my toolbox being mounted in the way and have had no problems. I measured the temperature in all the corners before I did it and the front was the same as the rear over there.
See? Easy.
Just a little clarification in case your harness is all twisted up. I'm looking at part of a '76 under-dash harness right now and the double wire from the key to the ignition is 2 Red w/green wires connected to the 90° female spade connector that snaps into the plastic plug on the back of the key switch. The large one is your resistor wire to the coil. About 5' down the line the Brown wire from the solenoid is spliced into it. The smaller Red w/green wire goes to a splice about 6" from there and off to multiple paths including the Blue wire to the module, the Purple w/white and Red w/yellow that go to the dash mounted Dual Brake Warning Light and the Green w/red to the voltage regulator. That last one is an important item to keep track of if you don't already have the VR's circuits dialed in.
My diagram shows another blue one and another Red w/yellow going to the carb's emissions control items, probably a CA only thing.
Hope that didn't cornfuze things more.
What're you still doing up? Hah! Or maybe you're just getting up to go to work? On the truck?
Later.
2badrotties
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
The harness I used in this bronco is a 75 harness and it was in good shape except the alternator wiring and I had one loose wire in a small harness that goes to something emissions. Everything under the dash was good. All of my plugs look good. I'm hoping everything goes smooth now.
Why am I up ? Because I'm on vacation thats why. I always get up early when I don't have to go to work ;D . I want to finish this Bronco up this week and I still have a little to do. It SHOULD be turn the key ready by the end of the day. Then it's brake job time. :) . I think I'm going to take a little nap first though ;)
4byford
Yucca Valley CA
THis is a goopd thread, it should be summarized and put into the tech section under "Isolator wiring for dummies" or "Alternator spaghetti".
What do ya think, "Fred"?
Thanks for sharing your knowledge!
