I just finished my hydroboost project, now moving on to a FITECH fuel injection system install.
The frame mounted electric pump is gravity fed and you have to mount it below the bottom of the tank, which is nearly impossible with a larger aftermarket tank. The mechanical pump doesn't put out that much pressure, so can I use my mechanical pump to feed the frame mounted pump? I really don't want to spend the extra $$ for the fuel commander unit...
