There you go! That’s how it works.
Have you ever worked on a track bar before?
There are multiple ways to skin the cat if the upper eye doesn’t match the hole that you want.
The easiest way I have found is to work on it with the tires still on the ground. Don’t bother to jack anything up.
Remove the upper bolt and lower nut, rotate the bar down out of the pocket (you may have to use a prybar to free it) then install the new one reverse.
Don’t tighten the locknut on the adjustable end just yet. You’ll likely need to adjust the length unless you get lucky, and you will also want to adjust the eye angle to fit in the pocket better with your lift.
When you lift a bronco the same thing happens on the radius arm as happens on the track bar. Things pivot.
Put the new bar on the lower bolt and run the nut up just enough to keep it on.
Rotate it up to try to get it in the upper hole. If you’re lucky, or very good(
), it’ll pop right in.
If it doesn’t line up, have someone turn the steering wheel slightly to move the frame over the axle until the hole lines up.
That’s been my go to method for almost 50 years. Works like a charm and is easier than a ratchet strap sometimes.
You can even do it by yourself if you can reach up and grab the steering shaft by the steering box. But that’s not always possible with every set up.
Have fun!
