- Sep 20, 2018
- 322
I previously posted that I installed a new hydroboost unit with a dual return Saginaw pump and rebuilt my steering column.
I have burped the system as per the instructions and even did additional cycles. I have also tried another technique and still feels the same like having to fight the steering wheel while driving, doesnt feel smooth.
I am just thinking outloud;
When there is no load on the front (tire s off the ground) it feels like the steering wheel turns back and forth smooth. When the tires are on the ground and the truck is on and in park, the steering feels smooth but when you put it in drive feels like it gets tight again and doesn't turn smooth. It's hard to describe,
Does this make sense?
Again, thinking outloud, could it be a bad steering pump? Could it be a bad hydroboost unit?
Has anyone else had these symptoms after installing a new hydroboost unit and rebuilt column?
I also installed a new H block (drum/drum) , could an issue with the h block contribute to these symptoms? Doesn't seem like it makes sense but just thought I would mention it.
Any and all help is greatly appreciated.
Thank you in advance for your time/help,
Sonny
Sonny
