F'ing intermittent starter issue
strokers
I would trouble shoot this by taking a thick wire and manually activating the starter solenoid. Cuts issue in half. But my guess it starter relay isn't getting enough voltage/amps to fully activate it.
Steve83
Viperwolf1
electron whisperer
OK So it's gonna be worst at the terminals, where there's more acid, and where it's most concentrated - that's what I was talking about.
Sure, until the terminals are cleaned because someone said that's the only place corrosion happens. And it still doesn't work, so things like starters and batteries get replaced for no good reason. And it still doesn't work.
chuzie
chuzie
Sounds like you had quite a nightmare. I will clean my grounding surfaces before i start shooting wires. Thx.
chuzie
chuzie
Cleaned ground on starter and case. Repeated once but not since. Time will tell.
chuzie
chuzie
Well, the problem is back. Seems to duplicate more often now so maybe I will be able to do the drop voltage test.
chuzie
chuzie
Troubleshooting again today. As I turned the key to START and got my typical no start single click of the solenoid, I held the key down for a extra second and heard a sizzling sound. I located the smell and felt for a hot wire.
Turns out it was my Maxi fuse holder which supplies battery power to the main harness, lights, aux power, etc. The pigtail wires from the holder were fine, but the holder was melting without the 60A fuse blowing!
I have had issues with this holder before as it does not do a great job of protecting the contacts from the elements. The only theory I have is corrosion built up on the spades of the fuse and caused the heating.
What does this have to do with the no start? Not really sure since the starting system is separate from this circuit with the exception of the ignition switch. We assumed the ignition switch was good since we had engagement of the starter relay.
I replaced with a better fuse holder from NAPA and threw a 40A fuse in there instead just to be on the safe side. It seems to be starting just fine now but it may be another false positive; time will tell.
Another strange observation, which I think may be unrelated, is my ignition switch does not fully return to RUN after engagement of START. It does not keep START engaged; thank goodness. Kind of like it is stuck between the two positions and I have to give it the slightest nudge to get it to seat in the RUN position. I recognize this condition because my Autometer gauges are setup to be powered via the RUN circuit and they are dead during START and come alive when the key returns to RUN.
The ignition switch is not too old. Maybe cheap Chinese crap?
Steve83
Yes, some fuse holders aren't actually made for the largest fuses of that type - you have to be careful going above ~25A with common APRs, and ~50A with APX.
Even original '80-96 fuse blocks burn frequently with the stock 30A blower fuse.
Jeremy0201
Tucson
Anyone else think this is a hot wire grounding out? Had this problem with my norton motorcycle all the time until I rewired. The click may very we'll be a pop sound... Sorry if I'm way off just chiming in
Viperwolf1
electron whisperer
Close to it. The starter mounted solenoid (very low resistance) is drawing more current than the ignition switch circuit can provide. Need to use a relay/solenoid with this type of starter. I believe I mentioned this way back near the beginning of this thread.
chuzie
chuzie
The sound is pretty distinct and familiar as solenoid engagement.
I may have missed that suggestion Viper. Relay will go in today. I need a relay for the relay; gotta love it.
Thanks fellas.
chuzie
chuzie
FWIW- I thought maybe I had a defective fuse that was not popping so I used a few APM fuses stepped from 50-20A just to make sure; none popped. I can't believe that housing melted from anything less than 20A.
Heavy duty APX holder, dielectric grease, and a 40A fuse to replace the 60A should help prevent this from happening again. That corrosion really is a hard item to track since I had no reason to pull the fuse considering I had power. My lights are brighter and the ignition works great.
Now if something this simple could explain why my brakes don't work, I would be one happy camper!
Thanks again!
