englewoodcowboy
Lick Creek Restorations
- Jul 25, 2010
- 4,201
The main reason I stay away from the command center is of all the research I did and the issues that arise, 90% of them involved the command center not being able to handle the environment the user has intended for it. Second reason, it sounds simple but is way more complex as you are now relying on your mechanical pump to fill the unit, then the unit to supply fuel in a return less fashion which again for more power or high heat scenarios becomes problematic. Keep in mind I am installing these for my customers and I want happy customers with simple systems that are as reliable as they can be in today's mass market quality. I also want to make certain that if someone has a problem, I can troubleshoot it easily over the phone etc or be able to quickly walk a mechanic through the setup and repair for my long distance customers.
