Fitech GoStreet Fuel Pressure / Pump Problem
BGBronco
N A S H V I L L E
Tennessee
I have a 76 Bronco w/302. Added Fitech GoStreet 400 w/ in tank fuel pump 6 months or so ago and had no issues (until now).
The Bronco will turn over but won't start. I have spark but no fuel. The pressure gauge is at zero and from what I recall when it was running, there was always pressure showing on the gauge. I'm not hearing the fuel pump but I don't recall if I heard it before.
Related, or maybe not, I have had past issues with the controller screen not working and it's definitely not working now.
Thoughts / Prayers welcome. Thank you.
MonsterBIlly
I had similar problems with my fitech. First, check the fuses and all the wire connections.
Second, borrow a handheld and a cable from somebody
And see if that one works. If not, it's probably the ecu.
I had these exact same problem
I fixed it by taking it off, and I bought a Holley sniper efi. It's much better, easier to tune and does not have the problems the fitech does.
BGBronco
BGBronco
N A S H V I L L E
Tennessee
Well. It was a fuse. I thought I checked them all but there was one on the end of the yellow wire (which I thought was for the Aux fan) that was blown. I'm assuming because it then ran to the Orange Wire (Fuel Pump) fuse which was goo that this caused the failure. Either way, everything is now operating as it should.
