Mikesimp70
- Jun 20, 2017
- 341
Got it running Saturday. Initial timing 10degrees, full mechanical advance 32 and vac advance is not connected.
302 w mild cam
Screen shots below are at idle. These are settings put in by my engine builder.
Issue is that if I am cruising at speed and roll out of the throttle, I experience a “stumble” when I start to press the throttle again. Its like the engine cuts out and there are some pops. AFR numbers climb. It recovers without stall but I have to believe the fix is simple.
Thoughts?
302 w mild cam
Thoughts?
