I stuck it in there and drove it a bit, but until I get it on the trail it’s hard to say. Next weekend maybe.
But on the other hand, fooling around with it, I remembered what it was doing that I didn’t like.
And please test this and let me know. Should matter what transmission.
While at a stop light or similar, with engine at temp and idling. Press the accelerator ever so slightly, move the rpm maybe 100 and let off.
Does it drop or continue to climb?
Mine- if I bring it from idle 850 to 950 and let off, it will hold the 950 for a fraction and then climb up to 1100 / 1200 hold it for a fraction and then drop back to idle.
This is the behavior I was trying to recall and relay. It does it while idling in gear crawling too.
Hinmaton
Hmmm, is this the Fitech IAC opening when you close the throttle? Under 1000 RPM, my engine will just return to idle after bliping the throttle. If I blip the throttle to somewhere like 1200 RPM, the RPM will start to drop quickly but catches itself, adds ~100 RPM and then slowly returns to idle. I didn't see the RPM increase over the initial RPM spike during the return to idle. I would look at Decel Open IAC, Decel IAC Decay &/or Decel RPM Decay. Also make sure your IAC is set 3-10 at warm idle.
