matt w
- Jun 12, 2007
- 2,799
I have been having overheating problems ON THE TRAIL
ONLY at slow working speeds!!
I have replaced all new coolant last week with a new
Thermostat. I have an aluminum radiator that was installed new in October. I have also installed a hi flow water pump. The thing runs just great on the highway but it just gets HOT on the trail. I do have shroud. I had it tuned up also last week! STILL OVER HEATS!
I was told to eliminate the flex fan.
I have it all torn apart and IT SEEMS that with the fan clutch installed that there is not enough room for this set up!!
SO my question is when the PO installed the flex fan is there an adaptor that the PO installed and NOW a stock fan and fan clutch will not work?!?? It sure seems like it!!!!
What part would I need to purchase in order to return to the stock set up!?
ALSO SHOULD I JUST KEEP THW FLEX FAN AND PURCHASE A 4 row radiator!!
This heating issue is rediculous!!!! UGH!!
PS ITS SITTING DEAD IN THE GARAGE WAITING FOR THE NEXT MOVE!;<{
Again thanks for your help and input!!
Matt W.
Matt W.
