Process
Ok here ya go
Coilovers i would recommend a 12" for this setup.
I will tell you there is a good deal of fab work involved in this setup.
I started with a dana 60 from a 97 Ford f350. Stripped it down to a bare housing. I used a 9" from a 79 f150 or bronco and used that as my width. I cut approximately 4" off the long side tube. This does alot to re center the pumpkin. I had a company cut a inner axle shaft for me.
Before you touch a thing mark where your old brackets were mark new lines away from your fab area and make notes. I put a witness line with a cut off wheel. I then measured everything.
Get your fav tool and clean the frame.
I cut the welds around The knuckle then cut it off flush. Take into consideration that the knuckle will take up 3" or so of metal mark the tube accordingly. Cut it pound inner c back on and set your caster the same as the other. Weld the inner c back on. Two to three passes on the the knuckle is recommend for this.
Now you will weld the Y link brackets to the tube. You pinion angle needs to be close when this is done.
I then built my arms From 2" .25 wall dom. Everything tacked on.
Axle side needs a Bushing and frame side gets heims.
Material list.
10 feet 2" .25 wall dom
Ballistic fab radius arm mount
https://www.ballisticfabrication.com/mobile/Radius-Arm-Coilover-Shock-Mount_p_1465.html
Ballistic fab poly bushing
https://www.ballisticfabrication.co...ly-Bushing-263-w-Weldable-Housing_p_1663.html
