I'm trying to figure out what I need to match up my c4 to a '93 351W. I purchased an FM124 torque converter, made sure it's seated all the way back on the output shaft. I measure 7/8" from the surface of the bellhousing to the TQ bolt pads. The flex plate is from the 351W and it was mated to an E4OD trans.
The Flex plate is a 164 tooth, 28oz, 11.5" bolt circle, but i think it may stick out from the engine block too far. It measures 1" from the block.
The bell housing will bolt up to the block but the torque converter binds when the bell housing bolts are snugged up.
I understand the FM112 has a slightly shorter pilot at 1.28" rather than 1.36" on the FM124, but im not sure that will be enough space.
Do I need a different flex plate designed for the c4?
Any help much appreciated!
