SSDDBRONCO
Hey all!
From my research in the past, I came to the conclusion that I can use the flexplate off my 302 with the 351 that I am swapping into my bronco since it's the same 28oz balance and teeth pattern. Is that correct or am I wrong? If I wrong what flexplate did you use for your 4r70w and 351?
You may have seen my post on Facebook Early Bronco group. But the reason I am asking this question is because I installed the 4r70w with the 351 and when I was going to tighten the bolts on the torque converter I was not able to turn the engine. Then one guy commented that he had a similar problem and used a different flexplate so Im just trying to figure out if my flexplate is the problem?
Thanks for the help!
Just to add for more info I was running a C4 before the 4r70w.
