Floor board help
steward
Can anyone give me some advice?iam currently replacing the floor boards in my 74,and some have told me to cut the old ones out ovelap the new ones about 1 inch over the old floor and weld it in, wouldnt this cause a bad place for moisture underneth? i realize that a butt joint would be difficult to achive all the way around the replacement pannel,so just currious what others had done.
also have to do the rear bed pan so any advice would be great.
Dan.S
boilermaker667
lost creek
floor board
if you over lap the existing floor board it will have an open area for water and dirt to lay in, also the two metals touching together will cause rusting problems down the road,
1975stroppebaja
Dan.S
If you remove all the spotwelds on the original floorpans you'll be able to lay the new one down right in its place and use all the original "lips" and put new spotwelds in place.
Rear bed pan is a similar process. If you do a search you'll find a couple recent threads, specifically one regarding the cross brace that's helpful.
Good luck!
Blue71
I cut mine out . Drilled holes all arounfd the new pan edge. Overlaped the new ones about 1" so that you have good metal underneath to weld to. Before welding..I sprayed a 3M brand... weld-through primer between the two metal surfaces that will be sandwiched together , After spot/plug welding the new pan in place....take a good automotive seem sealer. I used the 3M stuff and another brand (can't remember the name) that NAPA carries. I put it on the top side seem and went underneath the Bronco and put it on the bottom too to keep moisture out. Has done great for 3 years now.
Blue71
S
steward
thanks for the help
t
Thanks for the help guys I will keep you posted on how this restore goes
thanks again Dan.S
