Floor pan welding questions
asinor
Tulsa, OK
OK, so I'm about to replace my floor pans and bed. I thought I was going to get lucky and not have to, but it looks like it had a broken driveshaft at some point in its life that put a couple of good dents in it from the underside of the bed and the drivers side floor pan has some rust through, pitting on the pass side, but liveable, replacing since I have to replace the others.
I know I spot/rosette weld to the support rails.
The goal is to have a smooth finish that will look decent with linex or raptor. Time isn't an issue, finish is. I'm ok with welding, I have both arc and wirefeed, great with a grinder. I'll be using one of the vendors floor pan kits (undecided which yet).
Questions.
Do I spot weld, then seam seal?
or
Stich weld with arc all edges and grind? Taking all precations to avoid warping.
or
Mig all edges and grind? Same on the warping issues.
If I don't spot/seam seal, do I...
Do I flange the new sheet metal and fit it from underneath with cleco type fateners?
or do I flush fit it and use something like eastwoods intergrip panel clips?
I have no idea about seam sealer, doesn't seem like it will have the finish I am wanting.
surfer-b
Spot weld with the mig, just jump from one side to the other so you want heat the pan up too much and cause it to warp. You can weld as much as you like just let it cool then grind to your desire and seamseal.
