Floorboard coating options (not bedliner)????
Zeke
The floorboards on my '75 are great, but when the original carpet was removed it left the glue, which in turn took the orig. paint off:p .
I want to coat the floorboards and wheelhouses,but don't want to use bediner. I was thinking about "Hammerite" the floorboards in the textured type and use the smooth type (same color) on the wheelhouses and vetical surfaces. Anyone done anything like this?
Thanks,
Zeke
broncnaz
Using the rough hammerite is probably a bad idea on the floor boards as it give more space for moisture to collect. But I dont see why it wont work just wouldnt be my first choice for bronco floor boards.
TN1776
I would suggest automotive paint at a minimum. Spray paint in most all its forms (including hammerite) simply does not bond and seal as well as automotive paint, and tends to be UV sensitive, fading when exposed to the sunlight.
POR-15 may be an option if the floorboards are properly prepped (prep is everything with POR) and it too will need to be top coated.
I know you said no to bedliner, but spray-in bedliner in my opinion is among the better choices for floorboards. Its tough stuff that bonds and seals well (I used SEM Pro-Tex in mine, and after over a year of use/abuse its still holding up well).
Especially in a rig with good, solid original floors, you need to seal it up to keep it from rusting. Good luck.
Tito
CB Fire Starter
Bakersfield, CA
Anyone know of a clear coating that can be used on floors? Wouldnt need to be textured but would be nice to have something clear to put over a pretty stock or freshly painted floor. Like a clear rubber coating.
Hoppy
Gresham, OR
you might be able to use the same stuff that is used for basketball courts?
I think ElStarko used something along these lines for the awesome table at his beach place.
00gyrhed
Durabak smooth really looks nice when sprayed. Lays down just LIke paint. I rolled mine on just to get a little texure. May go back and spray over the top of it to get a little smoother look. My floors look kind of like texturing on dry wall. Someone on this board sprayed thier interior with smooth durabak and it looked great. It will last well and can be recoated if wanted. Just remeber to get the UV additive.
