Wet Floorboard
Jccolt1
Owasso, Ok
76 Bronco 302 auto with aftermarket A/C
Went for a short cruise got home and passenger side floorboard carpet was sopping wet. Was not running a/c or heat. Fluid did not have a smell or feel oily or sticky. What could be happening?
Slowleak
Georgia
If you were recently running the A/C, you may have condensation collecting in your evaporator housing. When you drive, it sloshes around and finds a way out. Check your drain hose to make sure its not plugged up.
J
Jccolt1
Owasso, Ok
I haven’t ran A/C lately. Can feel no water around heater box and the top portion of carpet under dash is not wet. It’s all in floorboard and extends under passenger seat. Last week it was at paint to have a spot touched up. It rained quite a bit, I think I will ask them if it set outside during rain, maybe it leaks rain. I never drive it in rain and I hand wash it. Thanks for your reply. I shall revert.
72Sport
Probably rain leaking through the joint where the cowl is attached to the sheet metal just below the bottom of the windshield. it is on the engine side of the windshield. Some body sealer fixed mine about 10 years ago.
valveamp
72Sport, Can you expand on what you did? I have a similar problem with rain water getting in under the dash and falling on the floor. Also, when I wash it, which is mostly the problem. What exactly did you put on it? How did you put it on? Do you have to drop the windshield? What did you apply it with? Where exactly does it go? Sorry for all of the questions, but I'd like to get this solved and, even though I've searched, I haven't found a lot of discussion on it. Thanks.
AZ73
The area around the cowl at the base of the windshield is seam sealed from the factory, but after 50 years the seam sealer gets hard and cracks, letting water through. The pictures are areas were I pulled all the old seam sealer out with a dental pick and will be replacing it with new seam sealer. This is the driver's side, but the passenger side looks the same. Mine was leaking as the area under the cowl had surface rust. We blew it out and shot a cavity coater in there
