So the mystery is the size of the holes for mounting assessories. That hole is larger than 9/16 it where the bolt for the power steering pump would normally go. The passenger side head is the same. Any ideas.. Will certainly need some Heli coils.
That is air injection port for smog pump. They are in both ends of the heads, and if you don't install all four thermactor plugs you will have exhaust leaks.
I think Summit has them, but I’m sure others do too.
Did you call the manufacturer to see if they had them? Or if they know what’s going on with the big holes in their heads?
