- Jun 13, 2012
- 821
Folks,
Getting closer and closer to firing up my 67 5.0 explorer swap. Currently working on the HB and brake lines and hoping to have that all wrapped up by Monday of next week.
Need recommendations for the following fluids
brake fluid type- Dot???
1985 dodge diplomat MC (Cardone # 13-1860)
wilwood 260-8419 Brake Proportioning Valve
disk/drum set up
Power steering fluid type?
1996 explorer 5.0 power steering pump
1996 explorer power steering cooler
2003-04 super duty remote reservoir from (Cardone# 3R905)
2001 super duty hydro boost unit
early bronco power steering box
Also for those who are using the diplomat MC does it matter which port to use for the front or rear brakes? since its a single reservoir makes sense to use the port closest to the firewall for the rears and the forward one for the fronts? just making sure before i run the lines...
Primary Port Size 1/2 x 20 rear port
Secondary Port Size 9/16 x 20 front port
Reservoir Type Single
JP
disk/drum set up
JP
