Flush LED MArker Lights
c17jack
I'm hoping someone here can help me out. Does anyone know if there is such thing as a flush mounted LED marker light. Basically one that you can screw or adhesive mount to the fender with only a small hole for the wires.
I have already painted the bronco and really don't want to cut the holes for the marker light buckets.
Thanks in advance Jack
destroyer000
truck light sells some small round style ones.. hole size is maybe half inch or so.. i used them on mine.. you put a groment into the hole and the light pushes into them.
c17jack
c17jack
I'm trying to find some that look like the stock lens if possible
Jfryjfry
75mike, that is indeed a great idea. You might see the paint through the lens though. Maybe put white tape around the light behind the lens
Maddog B
Post some pics when you get it done! I’m in the exact same boat you are.
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
markw
Good to know thanks for sharing that link.
Sent from my iPhone using Tapatalk Pro
