- Aug 17, 2004
- 493
1970 Ford Bronco with replaced engine from 1972 302.
My Flywheel is cracked and the ring gear is in bad shape. The original flywheel is 164 tooth, 11" clutch and 28oz balance with stamped C7TE-A.
I can't seem to find a replacement flywheel with the same clutch bolt pattern.
The flywheel bolt pattern for my 11" clutch looks like it aligns with the 157 tooth 28oz flywheel and 10" clutch.
Is there a 164 tooth flywheel out there with the clutch bolt pattern from the 157 tooth flywheel?
Right Clutch bolt pattern but wrong tooth (157) and 10" clutch.
CJ Pony Parts Part number: MTF1
Right tooth (165/164) but wrong 11" clutch bolt pattern
Jegs Part Number: 555-601350
Thanks all!
![157-28oz-goodboltpattern.JPG 157-28oz-goodboltpattern.JPG](https://classicbroncos.com/forums/data/attachments/927/927330-f28d263f64896db7f3a05985393e8d5b.jpg)
![164-28oz-badboltpattern.JPG 164-28oz-badboltpattern.JPG](https://classicbroncos.com/forums/data/attachments/927/927331-331cd0c0dbceb7d189961d16a11384a3.jpg)
Thanks all!
