? For those using an RJM & Centech harness
boonz28
I've searched and came up empty.
My question is for those of you using an RJM EFI harness and a Centech Body harness.
Where did you guys tie the RJM harness into the Centech?
There are 3 wires coming out of the Centech harness in the engine bay labled Oil Pressure (orange), Water Temp (blue), and Tach (yellow). Is this where you tie the RJM harness into the Centech??:?
Thanks in advance.
Seth
kjmssd
Salt Lake City
The two wiring harnesses do not hook together. The RGM harness replaces wiring in the Centec harness. The RGM harness is cool and duplicates the wiring inside of the wiring harness so that it keeps the engine wiring clean. They did this so that all of Your gauges will work without adding additional wiring.
When in doubt abandon the Centech wiring and use the RGM wiring.
boonz28
boonz28
But the two must connect somewhere right? If not then how does the signal from my engine sensors (connected to the RJM harness) travel to my gauges (connected to the Centech)?
Does this look correct?
Thanks for your help
Viperwolf1
electron whisperer
That connector on the RJM harness has oil pressure, water temp and ignition current. The ignition current is used to turn on all the relays. I'd replace the tach wire on the centech side with the ignition wire.
Correct. You need to get a couple of the usual Weatherpack tools if you don't have them already, and modify the orientation of the wires in a couple of the Centech plugs.
You basically create a 3-wire Weatherpack with the correct wires and match them to the RJM harness.
RJM does sell an adapter harness, which is basically the standard 3-wire push connector on one side to mate to the EFI harness and a 3-wire Weatherpack to mate to the (now modified) chassis harness.
You can make your own of course, but you just have to get the three wires that terminate near the back of the driver's side of the engine over to the passenger fender.
Ryan designed the harness to fit to a stock Bronco harness, so that existing 3-wire push-on would have simply plugged into the original plug coming out of the firewall behind the driver's valve cover.
Since Centech decided to put those wires through the firewall over on the passenger side, you just have to "punt" a little.
boonz28
boonz28
Thanks Guys, i really appreciate the help. Now i can keep pushing forward and hopefully start this thing soon. ;D
boonz28
boonz28
Ok, i'm planing on doing some wiring tonight and i just wanted to verify before i do this.
I'm going to make my new 3 pin weatherpack (centech side) out of these 3 wires.
Obviously Oil PSI and Water Temp will connect together, and "Ignition Power" (Centech harness) will connect to "Key On" (RJM harness).
Sound correct?
That's correct. It seems strange when you have the two Blues in one connector, but it's legit. You're just moving things around from what each manufacturer expected when they designed their systems.
Gonna work sweet!
We just lit up my buddy's '73 the other day. Didn't crank the engine, but checked for relay clickage, headlight lightage, blinker flickage, and all was a go.
Well, at least that was AFTER we discovered that the individual power posts we were using were actually connected underneath the plastic base by a common buss-bar! Oops..
After separating them, things should settle down to normal and once the key is turned, there should be a big shout of "it's aaaaliiiive!" out of us.
boonz28
boonz28
Awesome Paul, thank you.
I'll probably have more questions along the way but hopefully I'll have some relay clickage, headlight lightage, and blinker clickage of my own soon!!!
Thanks again
Seth
boonz28
boonz28
Ok wiring gurus! I'm nearing the end of this install and i can use your help again with the last few wires.
Here's everything i have left:
Picture 1, 2, & 3 are of the passenger side of centech harness in the engine bay.
There are 5 wires coming out of the harness near the end where the headlight plugs are.
Purple (Labled Start)
White (1 Term)
Red (Battery +)
Yellow (Alternator)
Green (REG S)
Picture 4 is of 2 wires coming out of the RJM harness near the relays.
Red (Battery)
Purple (TFI Start)
Pictures 5 & 6 are wires coming out of the Centech harness on the passenger side just past the firewall.
Purple (Start) just like further down the harness
White (1 Term) just like further down the harness
then two green wires terminated into the same plug
Green 1 (Reg S) just like further down the harness
Green 2 (IGN AUX)
I know that some of these wires are supposed to hook up to the starter solonoid but i'm not sure if they're all used or how the two harnesses work together.
Since I'm definitely a wiring/ EFI newb any help you guys can give me as to where these wires should go would be greatly appreciated.
Thank You
Seth
Hey Seth. I thought you'd have it all wired up by now. Hah! Not easy for the first timer, eh?
That's what the clearly written instructions are for. Ok, so the Centech instructions are not that clear. Even for an expert! But at least the RJM ones are I think. So in case some of my late night ramblings are incoherent, refer back to them.
And that's why they print everything on the wires!
Ok, one bit at a time:
Purple (Labled Start) - Attaches to the starter relay's "S" post (small one next to the battery side) usually the left side.
White (1 Term) - Starter relay's small "I" post (usually the right side towards the starter) and gives the ignition system a little more jolt juice for a hotter spark during the start process. If you have a big whopping fancy ignition system, you may not need this one. With EFI you don't use it.
Red (Battery +) - Just what it says. Hook it to either the battery directly or to the starter relay's large battery post. The large one from the Centech harness is what powers your whole Bronco basically
Yellow (Alternator) - For a stock-ish Bronco, this attaches to the alternator's "BAT" or "CHG" post. For a serpentine or other higher output alternator, this is not used. You have to go to Plan-B for that.
Green (REG S) - This is used to switch your original voltage regulator on. If you have a modern internally regulated alternator, this may or may not be used. The RJM harness already includes the counterpart to this wire. So more on that later maybe?
Red (Battery)
Purple (TFI Start)
The Red wire powers your whole relay array and gives the computer and all it's associated thingies power. It is expected to hook up to either the battery directly, the starter relay at the battery cable stud, or to some other power stud that you may add for that purpose.
The Purple wire is to tell the computer that you are trying to start the engine, so it has to be hooked up to either the ignition switch directly (not easy) or the small "S" post on the starter relay.
Since both Centech and RJM are using the generic GM color codes, this Purple (or Violet as GM calls it) wire can connect to the same "S" stud as the other Violet wire from Centech.
Are those the two left over from your switching wires around in the 3-wire Weatherpack? If so, they're unused at this time. I just use Weatherpack well-plugs (available just about anywhere you can buy the connectors) in the ends to keep the weather out, even though I don't expect to ever use them. I just don't like cutting something off that might be useful someday.
In the pic you can see that they're just sitting their next to the two Green wires.
Green 2 (IGN AUX)
Just some extras in case you need another wire switched from the key. Good to have them there since we used to always be looking for some extras under the hood, but with both of these harnesses there's hardly a need. Don't know anyone that's used them yet, but it's still good to know they're there.
Just tuck them in under the rest where they'll be safe and out of the way.
That should be enough to catch something on fire or melt some wires. I'll check it again in the morning to see if I missed anything.
Not sure about that other section of Purple and White still, so will think on that.
The pic of the starter relay shows what you'd expect in a semi-typical setup. The large cables are from the battery positive, the starter-mounted solenoid (new style starter) and the alternator's new charge wire.
This last is what I was mentioning earlier. If you use a high output alternator you can't use the Centech's Yellow wire and need to make your own larger gauge wire. You can get away with smaller, but I used a 4ga because that's what was around.
Hooked the old Yellow wire to a terminal strip in the last pic and used it to power up the RJM relay bank. Fewer wires on the starter relay, and in this case the relays were too far away and the RJM wire was short. I could have extended it, but thought this was cleaner.
boonz28
boonz28
I lost my centech instructions somewhere along the way (also, the best way for me to wrap my head around electrical is to think of it as magic) so i greatly appreciate your late night ramblings!!!! ;D
Yes, those are the two left over from the 3 wire weather pack. I'll get one of those caps like you suggested.
hahaha this is exactly what i figured would happen if i didn't ask the experts here!!!
I think that should be everything i need (electrically at least) to get her running. I really appreciate you taking the time to spell it all out for me!!!!
You're the man Paul!
