I run an AOD out of an 87" lincoln. It's been upgraded with the better oiling output shaft. Wide ratio gear set, Lentech valve body and Art Carr shifter. The D20 is truely twin sticked with a KluneV 4:1. Right now I'm running 4:11s w/ 33" tires. I'ts pretty nice going down the road @ 2000 rpm on the highway. Plus, my mileage is around 20. The benefits of the Lentech, is to be able to electrically remove 4th, and to hold EACH gear. (The aod 2-3 shift is controlled by line pressure). Oh, and I also put a 900 stall converter in it. This truck was originally built for rocks, but it's a pretty good street driver too. Actually, with the injection and the drivetrain, it kinda gives the best of both worlds. No sputtering, runs down the highway at a normal rpm, and gets good mileage. Plus, the 115 to 1 crawl ratio is damn impressive. If I can help out with more info, let me know.
