(Ford EFI) IAB not working??
67EB_in_619
San Diego
So my truck dies when I put it in gear... going through diagnosis, I discovered that when I disconnect the IAB, nothing happens.. should stumble or stall.. right???
Assuming it should, I replaced it.. same behavior.
So.. with the engine running, I plugged in the old IAB to see if I could see the shuttle valve move.. nothing..
I didnt have time to put a DMM on the pig tail, but I am not sure I would see it anyway - might cycle too fast like an injector and I cannot find my noid light.
I dont know how to test this the rest of the way out... continuity from the harness plug? How can I measure to see if the computer is sending a signal or not?
I have a SnEEC, but that is one item that it does not show info on.. so in case anyone randomly has some aftermarket SnEEC software that is better than the crap I am running... I think I am manually diagnosing this.
Any tips or hints on troubleshooting would be appreciated!!
67EB_in_619
67EB_in_619
San Diego
UPDATE: I dont seem to have 12v @ the red wire in the IAB pigtail.. I do have ground on the white/blue wire (shows lower voltage as expected due to ON/OFF of the ground via the computer).
Reading shows that this should be powered by the same circuit as the injectors.. and since it does actually run, I will say the injectors are getting power. I checked all my fuses etc.. and they all show 12v on both sides.. so.. it looks like I am unwrapping this RJM harness??
ransil
before unwrapping check the wiring at the relays, the 12 volts is either spliced somewhere or pulled off the relay contact.
also check all the other places 12 volts goes to , EEC 37 & 57 MAF, fuel pump relay ect... it might clue you in to where a break is .( those are from the factory diagram RJm used multiple relays so he may have sourced 12 from something else.
67EB_in_619
67EB_in_619
San Diego
Checking... relay wiring looks good.. RJM really built a nice harness.. but I cannot find the source for the IAB power.. anyone know which relay it runs off of? I could trace both directions if I knew before unwrapping the whole thing.
67EB_in_619
67EB_in_619
San Diego
Ok.. so here is a public service announcement.
After unwrapping a good portion of the harness and triple checking relays and fuses, I decided to test the IAB circuit again with my noid light set... and what do you know.. it had voltage! The lesson learned? check to be sure your paperclip that your using to back probe the pigtail conducts electricity properly.. it looks and feels like metal, doesnt have a rubber coating, but didnt let the DMM show a signal.. go figure!!
So now that I know the IAB is working, I need to keep hunting for whatever is making the damn thing want to stall when in gear. Getting back to basics and cleaning the filter and MAF etc..
Viperwolf1
electron whisperer
Some of those IABs have a diode in them. If power goes to the wrong terminal it doesn't work.
67EB_in_619
67EB_in_619
San Diego
I replaced it with a new one.. verified via noid the harness and eec are working. And I notice a slight difference when I unplug it... So I'll assume the iab is working as expected.
I will probably take it somewhere to get tuned and given a once over to find what I can't. No unexpected codes... Just think it isn't running well at low rpm... It used to run better. I think it needs a wide band o2 and a more expensive scanning/tuning machine
Sent from my SM-G955U using Tapatalk
Rustytruck
Did you pull the plugs and take a look at them? How about checking the plug wires? I would be checking everything from the distributor out for an idle issue. Most times dealing with a stall dropping into gear is a vacuum leak issue. But I don't deal with fuel injection stuff much.
67EB_in_619
67EB_in_619
San Diego
That is a good point... It has been a while since I checked the plugs .. the wires look good.
I "feel" like there is a vac leak... But I cannot find one using the propane or starter fluid methods... Is there some way to pressurize with colored smoke or something at home?
EFI Guy
TheEFIguy@gmail
BFE
Make sure your PCV is routed correctly, including the fresh air side. It will act like a vacuum leak if you have it wrong. Also, valve covers must be sealed, no breathers.
Nobody
Stanwood
Since I'm running an automatic ecm with a manual transmission I had to one these idle air adjuster plates Completely resolved all stalling issues. These plates were actually a fix from ford for idle issues.
If you try to clean the IAB solenoid, you will likely break it. The internal plastic is extremely brittle.
[youtube]zR8nZFDE4hM[/youtube]
67EB_in_619
67EB_in_619
San Diego
EFI Guy (Ryan?) - I will double check my PCV routing.. I know I have it going to a big port under the middle of the intake, but I DONT think I have that "T" setup to grab the driver side port. Can I "T" that a second time to power my brake booster?
Also, I have a valve filler cap that I am sure doesnt seal up tight that has a port on it that I connected to the port on the TB housing.. the other side is capped off for sure. Since the valve filler cap port is upstream of the TB, that shouldnt be an issue, right? OR will the not super tight fitment of the cap be enough to leak?
67EB_in_619
67EB_in_619
San Diego
I have one of those too.. I figured out that my stroker demanded more air than the IAB could keep up with and that was a great solution without over adjusting my TB bracket
