I have stock 302 with a manual 3 speed and am thinking of getting the Ford Racing 306 engine. What parts would have to change to make it work.The 306 has a 50oz balancer and my 302 has a 28oz . Can I just change the 50oz to a 28oz and use my flywheel and clutch? The motors also have different firing orders can I use my distributor with Pertronix ? Is any one else using this engine and what do you think? My Bronco is just a weekend street truck with 4.11s and 33s
Thank you
Mike
I was looking at putting an explorer motor in recently, sticking with carb, stock front dress (including swapping timing chain cover to use mechanical pump), and duraspark and these are the minimum parts I thought I would need.
82-87 F150 302 flywheel (50 oz)-cheapest I found was $70 new-Advance auto
Clutch linkage adapter, since late model block has no threaded hole for clutch linkage
Bronco graveyard-$20
Wildhorses-$45 (comes with extra support that BGY bracket does not)
Balancer-50 oz
BC broncos, allows use of 3 or 4 bolt V-belt or 4 bolt serp-$125
Summit also has one for $77 dollars, looks like it has multiple sets of holes, not sure if it will work, see SUM-163302
Steel Distributor gear or remanned distributor with steel gear.
In my case, would be 1985 stang GT which had roller cam and still used duraspark
