Fore low not working
Billsboat
Rowlett tx
So I've had the 71eb for 6 months now and took it out today for the first time in the mud. So for some reason the 4low will not work. It goes into gear, and u can tell its in the low range but only the back tiers will spin. I got a little nervous cause I was stuck, but then put it in 4hi, and out she came with mud flying. Also, I'm not sure if this has anything to do with anything but it was a real bitch to the transfer case out of 4hi . Any input would be great, thanks!
bax
Old Member
Well the fact that you did have 4 wheel drive suggests that you may have a transfer case shifter problem. have you ever had the truck / drove the truck in low gear?
You didn't shift all the way in. There is an extra gear position not labeled on the shifter. 2WD low range. It is the position between neutral and 4WD low range. You needed to move the shifter 1 more notch forward to get 4WD low range. This is just the normal workings of the T-shift transfer case you should have in the '71
JSBX
What Broncobowsher said. Put it back in what you think is 4 low with the engine running as you are coming off the clutch bump the shifter forward. Sometimes the Bronco may need to be moving forward just a little for it to go into 4 low. Do the same when taking out of 4 low or 4 hi.
americanhorses
Clovis, California
My knuckles are almost in the dash when I engage 4lo
WILDHORSES
USA
I think you need a twin stick. ;D Well not really but it does make shifting the 20 easier. Just apply a little more force to pop it into 4 low.
bknbronco
North Metro, MN
2 wheel LO is a great option sometimes! Most vehicles you don't have that option.
Like suggested I don't believe the lever was fully forward. There is a position just short of 4LO that is 2LO....it just don't have the notch ground in the shift plate.
Its almost necessary to have the truck rolling or at least rocking to get the T-case lever to move.
If the bushings/linkage are worn too much and you still have the lock plate in place you may not have enough travel in the shifter. The quick fix it to take the lock plate out. Makes it like the original '66 shifter, count the clicks to know what range you are in.
