Fox suspension question
Iwannagofast
I am new to the forum and new to the bronco world. Just recently picked up a 1977 bronco and wanted to add a lift kit on it. I am looking into add some fox racing suspension. This will be just for show and not actually racing so does anyone know where to get these or what takes to do it or how much? any leads or info would be great. kinda looking for a set up like this but maybe something a little new set up sense this is pictures from I think a few years ago?
http://www.jakesmotorcars.com/web/vehicle_photos/10995912
Hey Ryle, welcome to classicbroncos! Nice going on finding a '77 too. Always liked the gas doors myself.
When you say Fox suspension, do you mean just the shocks, or the whole suspension? Not sure they make something for the EB's like that, but maybe they do because I've never bothered to look.
But there are some here using the shocks, so might have some insight for you.
The one in the pics looks to be running leaf springs in the rear still, and longer radius arms (or links?) so could still be running coil springs. I didn't see coilover shocks, but didn't look too long at the pics. Nice Bronco!
Good luck. Sorry I couldn't help but wanted to jump in with a welcome.
By the way, you looking for just show, or will you be driving it too?
Soylent
California
Looks like coil springs with standard 2.5 Fox remote reservoir shocks.
Sent from my SAMSUNG-SM-G870A using Tapatalk
I
Iwannagofast
Thanks for the replies, I am trying to see how this gentlemen set this bronco up. If anyone has any insight please let me know.
ame
Those are a standard Fox 2.0 Factory series shock, you can get generic Fox shocks by length to essentially fit any application but for best performance they should be valved to the spring rate, weight and use of the vehicle otherwise its really more for looks then function.
bronconut73
Soylent is right.
Typical coils and 11 leaf leaf packs with very good Fox Shocks.
I am sure it rides nice and articulates well but nothing exotic there.
Do they describe the height anywhere? Looks pretty tall, but with a better-than-most turned out steering setup for the height.
Off hand, I'd say it's 5.5" of lift plus body lift, with 37" tires on 17" wheels with custom high-steer arms and "GM 1-ton" steering links and a custom trackbar riser and loads of other hand-fabbed parts not available on the normal shelf.
Anything over 3.5" of suspension lift is a study in commitment to the cause. You gotta wanna, as George Carlin used to say.
But as you can clearly see, it's very doable. Just takes time, money and skills. Whether you or the shop that puts it all together.
Does look good though!
I just quickly glanced through the pics, but didn't see the usual long laundry list of "horrible things not to do to a Bronco" for once.
Moon's74
Henderson, NV
Looks like F250 shock mounts up front with all stock shock mount locations otherwise. Pretty good setup, but very high. I did the same thing with 2.5" lift. Looks great and rides wonderful. I use 10.5" fox resi's up front and 12" fox resi's on rear with shocks mounted forward in rear, see pic. Like I said, looks great and rides great. Purchased the front mounts from Ford and the rear mounts from a vendor in the vendors sections on this sight. Springs are all TBP soft ride stuff.
I
Iwannagofast
What did your set up end up costing you? Thank you!!
Moon's74
Henderson, NV
The rear leafs are about $350, front coils about $120, front shock mounts about $60/ea., the big stick are the shocks. New they start at $220/ea. depending on where you find them. I found my fronts on local craigslist but had to bite the bullet for the rears. I found the rear mounts on this sight, I think Vintage Ironworks, but I don't see them on here anymore. If I recall I think the pair costed about $250.
So, all in all, with new hardware and such, you are looking at around $2K. The shocks alone being about half.
Is it worth it??? Worth every penny for me, but as you can see if you've looked around here, this is all relative and there are many more, less expensive, alternatives that I'm sure ride and look just as good, some even better.
I prefer this setup for me! Hope this helped.
smoktf250
Vintage stopped making all of their stuff :(
Not to Hi-jack but im looking to run some king emulsions with the duff 2.5" coils. Any recommendations on shock valving
