Hi,
I am running the Duff steering linkage and they require to weld on the track bar riser bracket. That makes it so the axel mounted bump stops don't work because the riser bracket is taller than bump stops. I got the larger rear stop that toms sells and drilled and taped a hole for them in the frame (see pictures).
My questions is are they in the right place. I just centered them on the spring mount as that's the center of where the axel is mounted but looking at them installed it seems like it should be forward a bit more. Anybody have experience with this. My frame is going to powder coat and I want to get this right before so I don't have to fix anything after its back from powder coating.
