Front axle hub assembly tool
B
Boss Hog
You need the Chevy hose. Not sure about the Bronco Graveyard link you posted. I'd give them a call to find out which conversion this is for.
Here are a couple of part numbers I dug up from old articles. Sorry, but I don't know if they're accurate anymore.
Napa - 4136761
Checker & Autozone - 77028
Spoke with the guy at bronco graveyard. He was alot of help. This is what I ordered.
12564 Proportioning Valve for Disc/Drum Brakes 1 $59.00 $59.00
12553 Master Cylinder Lines, 1976-77 Hard Lines 1 $40.00 $40.00
12117J Disk Brake Conversion Caliper Hose 2 $16.00 $32.00
13000 C-Bushing Kit, 2º 66-75 Black, 14 Piece 1 $48.00 $48.00
19900 JBG Catalog 1966-77 Ford Bronco 1 $0.00 $0.00
18294 Side Marker Lens Hardware 66-77 (Does One Light) 1 $2.00 $2.00
12514 Front Axle Brake Lines, Pair Steel 1 $25.00 $25.00
18234 Fender Bolt 66-77 (Each) 2 $1.00 $2.00
I installed the outer snap ring but left the inner one off. Ordered fender bolts to take care of that. Thanks guys
Skiddy
good deal on the parts. your more than welcome for the help, i think you have it down pretty good now;D give me a holler anytime.;)
B
Boss Hog
Napa - 4136761
Thanks, they had them at autozone but they are cheaper at bronco graveyard.
