Front Axle Hub Install
greatguy57078
I have a 1968 halfcab that I have to go and pick up before the snow flies. The problem is that it has the front axle housing but nothing to bolt wheels onto. How hard (and cheap) would it be to pick up a set of hubs for a Dana 30 and bolt them up so I can roll it on and off the car dolly? Or would it be cheaper/easier to just bolt an entire axle on? I would appreciate any information you might like to share. Thank you! ;D
TBS-POPS
valley springs, ca
Would be really easy.. All you would need is the hubs with bearings and the spindle nuts. dont even worry about the brakes...bolt some wheels on and roll...
greatguy57078
greatguy57078
I am using a car dolly, so I have to have all 4 wheels and tires mounted. It is also about a 7+ hour drive back home, so it has to be able to make the trip home.
Tito
CB Fire Starter
Bakersfield, CA
That seems like something you would do Josh!!! We've seen the pics of your move!!
Hahaha, I have done worse ;D
Actually I used a uhaul dolly once and transported a Bronco on 3 wheels and a block of wood...nobody seemed to want to be in the lane next to me the whole trip back from Seattle. It stayed put! Who'da thunk?
