- Mar 9, 2026
- 7
New member here, I just bought a 74 Bronco 302 auto and want to upgrade all the shocks, bushings, tie rod ends, ball joints, steering damper etc. at the time of purchase it didn’t have a top then just a few days after making the deal in San Antonio Tx , I live closer to Dallas about 5 hours away I found a top for sale about 30 miles north of San Antonio and was able to arrange the transport company to stop and pick up the top also. The gentleman I got the top from said it has the Dana 30 front not the 44. He also recommend I join this sight. My question is do I need to order all the front end stuff for a Dana 30 or is it the same for the Dana 44? I did some investigating and see the differences between the 30 and 44 but looks to me I can order all the rubber bushings tie rod ends etc for either the 30 or 44 and it should still fit. I can’t fathom why he swapped the Dana 30 over the Dana 44? I also want new shocks It has 35” tires so I’ll need to measure from the top of the axle to frame to see if it’s been lifted. I bought the Bronco from a lady it was her husbands and he has passed so she doesn’t know anything about the truck. It doesn’t seem to be stock. Took a magnet to the heads it has aluminum heads long tube header AC corbeau seats winch roll bar disk brakes Edelbrock 4 barrel carb and intake. I need to do a compression test to see if the motor was touched sounds like it might have a mild cam. I just had back surgery to I can’t crawl under it yet. Thanks for any advice!
