- Dec 8, 2010
- 16,289
How did I get in this? If you want pictures just ask. I did not want to mess with your thread. Im good with it.
Hey I thought your name was Chester now ?:?
I also question the strength of a tube front cage leg after it has 4-5 bends in it to follow the dash line tight compared to a 1/2" piece of high quality plate steel bolted to the door post and then the front leg can attach to it with only 1 bend at the roof to windshield angle. I think of the door post as preventing bending of the plate also.
This is a heavier duty version of the same idea. The main difference being that they put a custom dash into this Bronco. But I think you could put an original style Bronco dash in with this cage, it would just need have a couple inches shaved from the edges.
I would not question the strength of this bad boy. Those pillars look stout. But less intrusive than your standard tube pillar at the drivers foot.
If you look at both of these cages though they are not plates, the bottoms are small low profile boxes, which have been dimple die-ed as well. So basically they are custom sized square tube and they dimple- die-ed and sleeved them to give them further 3D structure. These are not really examples of plate bottoms because structurally they are tubes but they are a clever way to get away with needing 3d support, they made the tube wider but narrower and then added the holes on the wider axis to give the box tube the same structural characteristics as the traditional tube. This is a really slick design.
