- Aug 22, 2005
- 14,497
The OP asked me to post this link on his thread.
http://classicbroncos.com/forums/showthread.php?t=246390
so if I take my lower legs and bolt through the side firewall and on the other side there is also a plate, but that plate has a piece of tubing running from top to bottom that's cut in half.....would that provide some decent 3 dimensional strength?????
Looks like it done got squated in the back.
Not what you want to do, I get that.
I do think that what you do want to do isn't something that can be done SoP on a forum. It really should be designed & engineered by someone who knows what they're doing.
Such drama!Oh god here we go another crash cage able to withstand 400mph wall crash.
You cant have NO I your heart! I know it can be done...hell im half way to being done. There isn't much in designing a cage to keep your truck on its side in a tip over. A single hoop behind the drivers seat is sufficient, so how come so much negativity about wanting a tad bit more protection than a stock style single hoop.
Maybe if I wanted some help I should have started another "my 351 overheats in July and I live in Arizona" thread
Maybe ill let this thread die and then repost my finished pics next summer. Thanks to those that helped along the way...I appreciate the negative comments as well, keeps me on the right path.
If he's around to hear you say it, then you'll be wrong....if/when it collapses like tin-foil because it was poorly designed and/or fabricated I will say that I told you so.
If he's not around to hear it, why waste the time to say it? ?:?
What is the difference from bknbronco's design, and the cages you can get from poisonspyder and I see other company's are making the front cage using the same design as poisonspyder. It looks like they are using flat steel to support the front cage. Having some type of front support is better than nothing. http://shop.poisonspyder.com/Jeep-Full-Cage-Kits-s/68.htm
