Front Disc Conversion Pads?
broncosam
My Bronco has a front disc conversion on it done by a PO. While I have this thing apart I want to put a new set of pads on it but I'm not sure what to get. From looking at everything I'm thinking it will need pads for a late 1970's GM truck or Blazer but I'm not positive. Hoping someone can look at the pictures and give some insight on what brake pads I need. Thanks
Mostly correct. The calipers and brackets are specifically for something like a '74 to early '76 GM K5, 10, 20 and maybe even some of the K30's.
From my understanding though, the pads remained the same all the way up into the '80's even though the other major components changed.
I don't remember the common number (a "D46" or something along those lines) but the parts listings should show the same number across many years and truck ratings.
Good luck. Sorry I did not have the exact number memorized. Member PaPitt is always quoting it and I never seem to be able to pull it out of thin air when he's not around.
WILDHORSES
USA
Not seeing much if any clearance between the caliper and knuckle. Could be the angle. As long as you are in there make sure the caliper can move as the pads wear. I like calling it 1975 Chevy Blazer pads.
Jim
.94 OR
Looking through the window of the caliper it appears to have plenty of remaining pad.
The caliper clearance does look suspect though, as I just did mine.
Looks like at least one pad has plenty of meat left on it. Can’t see the other one though, which seems strange.
B
broncosam
The pads are not worn down too bad, maybe at least half of their life is left, but I just rebuilt everything on the rear brakes and thought that pads aren't going to break my wallet so while I have it apart I would go ahead and put a new set of pads on it. As far as the clearance goes between the caliper and the knuckle, I know they look a bit close but I drove this thing all last spring and summer and never noticed anything unusual in the way it drove or handled.
sprdv1
REBEL
Jim
or just get a new correct set up from WH....
sprdv1
REBEL
That's good.. Safety first specially in these old rigs
If replacing, now's the time to spend a few extra bucks (maybe) for some high-friction performance pads or something along those lines. One of the higher end products that are not high in metallic content that take time to warm up.
I don't know what brand or model that might be for a Bronco, but I wanted to mention it in case you were given multiple choices in pad materials. Which you likely will be.
paul
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The GM brake setup is a sliding design where the caliper will move closer to the knuckle as the pads wear. If the knuckles aren't clearanced correctly, once the pads get below a certain thickness, the calipers can no longer slide to take up the slack and your brakes will not work correctly.
B
broncosam
Thanks I did not know that. I'm not real familiar with the GM brakes but have worked on the Ford disc set many times over the years. Can you or someone else post a picture of what and where the knuckles need to be clearanced, and can that be done with the caliper in place or will it need to be done while I am replacing the brake pads. Thanks
toddz69
The clearancing needs to be done with the caliper removed from the backing plate.
Todd Z.
904Bronco
San Martin, CA
Here is an example...
I have found that sometimes you don't have to take as much material off as shown in the pictures.
B
broncosam
Thanks for the help and the pictures. I went out to the garage and took a real close look at what I had and yes the calipers are real close to the knuckles, almost touching on one side. When I pull the calipers loose to install the new pads I'll work on getting the clearance I need on the knuckles.
Apogee
FMSI D52 spec pad...basically what GM put on everything from 1968 on for a couple decades. All of the applications noted by folks above will get you what you need. Keep in mind that the caliper body slides inward as the outer brake pad wears, so factor the friction surface thickness into your clearancing on the knuckles.
In addition to 904s pictures we should have full instructions on our webpage for the disc brake conversion as well. You should be able to use those to good effect.
Nothing wrong with having a couple of points of reference.
B
broncosam
Sure do appreciate everyone's input and help with this. Thanks
And if you start to actually shop for brake pads, there are probably over 100 different compounds for that caliper. It is a super popular pad size and many of the big pad manufacturers offer different pad compounds. Wilwood has 8 different compounds alone on the Speedway Motors site. If you get away from the box parts stores and start looking at speciality sites you can find pads that match your needs best. You can get different cold performance (trail use where they don't warm up) hot performance (exiting that downhill exit ramp off the freeway that is a bit too short), dust (keep those wheels pretty), noise, wear, etc...
That is one of the huge benifits I know of using the GM brakes over the Ford brakes. So much more choice in pad material. It is almost like picking a camshaft. So many choices, if you know that there are choices, if you only know of 2 or 3 options, you don't know what you are missing.
B
broncosam
Got those steering knuckles clearanced this afternoon. End product looks pretty much like the pictures that "904Bronco" posted. I took my time ground a bit off at a time. I think they will be fine. As for brake pads, I've always had good luck with some type of ceramic pad. They seem to wear good with low to almost no brake dust.
