Front hinge post (pillars)
greatguy57078
I have a Bronco that has pretty solid door posts but the bottoms are rusted out. I planned on running some type of "rock ski" anyways, but what can I do to patch these above where the ski would attach?
Should you replace the whole part or is there an option to repair the bottom 1" or so that would attach to the ski? %)
surfer-b
Depends on how bad it is and if it has good support for the door. For a trail rig, as long as the it was solid where the hinges attach, I would simply cut that part out and weld in new. It doesn't have to be perfect as long as it supports and allows the fender to bolt up.
Timmy390
Conway, AR
When I replaced my rockers I found mine to be the same way. I cut out all the rust and used what was left of the parts as a guide to fab up new ones and welded it all back up. It turned out great and solid as a rock. Added some spay on undercoating to it and good as new.
Tim
greatguy57078
greatguy57078
The rest of the door post is solid as a rock. It's just the lower 5-6 inches that has rusted away.
I am going to install some rock ski type covers like in the pic. This is for a street rod Bronco so it doesn't have to take a beating. I just want it to have a finished look and shorten the profile of the truck from the side view.
I will be capping the ends and making them look to blend more into the body where they meet the wheel wells.
