Measure everywhere, point to point, front to back side to side, those post n the pics look like the ones from tom's. I got one from them and on the inside of the post, the brace for the hinge plates was not welded to the back side of the post . That was making the post wider then it was supposed to be so I welded it and it brought it to where it should be;Probly also helped the door not sag because there was nothing for the brace to attach to. Also had to trim off the top, and bend the tab that is welded to the bottom of the cowl down 1/4 inch so it would sit under the cowl at the right height. I measured off the floor to the top fender bolt hole.wow, sorry for the long story hope it helps. also make sure everything is sitting level then take all the measurements.I also put in a brace from the trans. tunnel to the underside of the cowl to hold it up
