Front or Rear locker
rulebreaker
Manton MI
[quote author=thedirtyneck link=board=5;threadid=19812;start=0#msg151998 date=1057786512]
I am planning on buying a locker but i can only afford one. I think that a front locker would be my best bet. What does everyone think?
This will be in a 77, so dana 44 front and 9"rear. Did this year bronco come with limited slip of any kind in either diff? thanks
has anyone ever used these?
https://offroadlockers.com/index.html
[/quote]Put a locker in the front and throw a cheap mini spool in the rear till you have the $ for a detroit.
Steve
Grand Junction, CO
Odds are that your front 44 has a Trac Lok in it already, which is limited slip, although not a very good one. However, if you're locking it for serious wheeling, definitely lock the rear first. With a locked rear and either open or LS front, you can go about anywhere. If you lock the front and have an open rear, you won't be nearly as capable.
Oh yeah, if you're going to lock the rear and plan on going with stock 28 spline axles, DON'T DO IT!!! Go with at least 31 spline alloy shafts or you'll regret it big time later.
67halfcab
Michigan
[quote author=rulebreaker link=board=5;threadid=19812;start=0#msg152007 date=1057787628]
[/quote]
I second that. Hey, that's what I'm doing. ;D
The mini spool cost less than $45 with a new pin and unless you are a really really hard core wheeler your rear axles will last with the mini spool until can afford to upgrade.
