NYLES
- Aug 13, 2004
- 9,846
I said bang for the buck!
Let’s face it to upgrade the rear you need to maintain drivability (street driven rig) and dependability so you don’t break and get stranded on the trail. To do that you need a 1k locker, something with decent street performance & superior off road performance (selectable locker or quality LSD, etc). Then of course to ensure you don’t snap shafts you need to upgrade to larger spline and/or stronger material such as cromo. All said and done and you got 2k+ in your rear end and locker setup.
The front however can be very easily upgraded with a simple and cheap lunch box locker. Let's face it the front axle remains stationary and disengaged 80% of the time anyway with a street legal rig. Front Dana-44’s are relatively strong in stock form and worst case if you do break something, it ruins your day of wheeling instead of leaving you stranded in the bush needing both field recovery and a tow home. You might have $500-600 bucks in a front lunch box locker all said and done.
Griz and Detroits run fine in the rear? if its steering the front you prolly need stiffer front shocks......only issue is if you live in ice snow land then yea go with the ARB's.
